Can i improve my fan mounting/airflow by any way?
Daniel123dk
Heres a picture of my system:
Front: 3x120mm Silent Wings 2 PWM (Intake)
Rear: Corsair AF120 QE (Exhaust)
Top: 2x Corsair AF120 QE (Exhaust)
My cooler is the Dark Rock Pro 3, with both fans running at their minimum speed. all other fans run at moderate speed while being completely silent.
But, can i improve my airflow, does it help removing my fan filter in the front? i dont care about dust.
Thank you :)
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
You dont care about dust? Thats weird. The Airflow looks good enough for me. If your temps are fine. Just leave it like it is.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Should that fan be removed or should they be turned the opposite way and intaking or what do you mean?
Built  Not Bought
In theory, removing the fan filter will help airflow, but I doubt it would be anything significant to sacrifice dust-prevention.
As for my advice, I don't see anything wrong with what you have. Is there anything wrong with your temps? If not, I'd just leave it.
EVE (My Gaming Build)
Motherboard: Asus Maximus VII Ranger - CPU: Intel i5 4690k @ Stock Speeds - Cooling: Phanteks TC-12DX - PSU: Corsair RM750 - GPU: MSI GTX 1070 - Storage: 1x 120gb Samsung 830 Evo SSD (OS Drive) | 1x 120gb Hyperx 3k SSD (Audio Editing) | 1x 480gb Sandisk Ultra II SSD (Games) | 1x 1TB Hard Drive (Mass Storage) - Case: NZXT Phantom 530 - Misc: NZXT Hue RGB LED and controller
I dont care about dust, no, i have not experienced dust in any of my other builds in cases with no air filters.
Built  Not Bought
overtime you will have lots of dust in it, but if you have air compressor or air can, every 3 months or 4 you can just give a little clean.
At load, the cpu sits at about 52 degrees celcius (not overclocked atm) and the gpu sits at about 73 degrees celcius (gpu is boosting to 1379mhz)
Built  Not Bought
if you care about esthetic leave it there, but you're exhausting fresh cold air..
otherwise remove it for less noise and better positive pressure.
Yeah, you are right, so whats about that picture? and that fan thats pointless? care to explain? :)
Built  Not Bought
would it be completely stupid to make the two top ones intake instead? :)
Built  Not Bought
yes, hot air rises. top should be exhaust.
just quick image to explain. this case has psu mounted on top but you get the idea.
Ah okay, well, i would keep it just for looks, i think that it would look stupid with only one fan upthere :D
Built  Not Bought
 your PC would have better temps if the 3 intake front fans would be facing the ground. (your pc would be turned 90 degree)
also the "be quiet" logo would be on the right side. would look less stupid  B)
My Fan mounting looks similar to yours. And i know i dont need all of them, but i like the look of it.
I use Dustfilters tho. 4° more is worth it for me.
post-227208-0-07402900-1453558018_thumb.
i like the look of yours, thats sexy :D
Built  Not Bought
I might try it out, otherwise, if i dont like it, im just living with it :D
Built  Not Bought
changed the temps of the arrow. lol
