Specs:
Intel i5-4460
16 GB Crucial Ballistix Sport (4x4)
B85M-G R 2.0
MSI Geforce GTX 970
Corsair 100R Carbide Edition
Fans:
Duo Corsair AF120 Quiet Edition (Top 2 Slots)
Stock Corsair Fan ( Mounted on the Back)
Then Stock CPU Cooler and Twin Frozr fans on the 970.
Do I need to Invest in More Fans? Or is this sufficient
- Thanks
  • CPU: E3-1241v3|| MOBO: Asus B85M-G R 2.0|| RAM: Crucial Ballistix Sport (4x4) 16GB || GPU: MSI Geforce GTX 970 Gaming || CASE: Corsair 100R Carbide Series || Crucial MX100 250GB SSD + WD Blue 1TB || PSU: Sentey 750W Semi-Modular 80+ Bronze || Cooling: x2 Corsair AF120 Red LED Silent Edition
https://linustechtips.com/topic/532623-sufficient-cooling/
You're good. Usually using more/different fans than the stock setup are for people who want silence or overclocking.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/532623-sufficient-cooling/#findComment-7069611
your golden mate, more than enough cooling
Thanks for the Input!  :lol:
https://linustechtips.com/topic/532623-sufficient-cooling/#findComment-7069628
Noted. Thank you!
https://linustechtips.com/topic/532623-sufficient-cooling/#findComment-7069633
