I'm trying to help my friend out with upgrading his super old pre built HP desktop, here are the specs...
CPU: i5 2400 3.1 ghz
RAM: 8gb 1333 ddr3
GPU: Radeon HD 7450
PS: 300W
Motherboard: IPISB-CU  // p7-1245
All he is looking to get right now is a new (used) GPU something like a GTX 650ti, 660, 760 or 770
But I'm thinking he would also need a new PS, maybe a 500W is that the case?
But after some stuff I have read online it's looking like that while a lot of the newer cards will fit into this mobo,
they are not able to make it past the windows boot screen after they have installed the new card, due to incompatibility?
heres a post relating to what I mean http://www.tomshardware.com/answers/id-1987829/gtx-660-compatible-ipisb-carmel2-motherboard.html
Any info regarding his set up and what cards would be compatible would be greatly appreciated.
https://linustechtips.com/topic/531979-need-help-with-upgrades/
That CPU's socket was 1155, so any of those gpu's should be fine.
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/531979-need-help-with-upgrades/#findComment-7060593
Agreed. Should be fine with GPUs.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/531979-need-help-with-upgrades/#findComment-7060613
With regards to wattage, might need to check how much power the GPU's use before choosing one
My Rigs:
Case:
Case:
https://linustechtips.com/topic/531979-need-help-with-upgrades/#findComment-7060643
750ti dunno how much faster it would be
Otherwise just save up
https://linustechtips.com/topic/531979-need-help-with-upgrades/#findComment-7060989
  The 750ti would work that that PSU if you use a reference model, or just 1 without a power connector, don't quote me  on this though. I would suggest getting a PSU if you are doing this, it MAY need more wattage, not sure.
MOTHERBOARD: some Asus motherboard CPU: I3-4130 GPU: Gigabyte(?) GT-1030 RAM: 8GB G.SKILL SNIPER 1600MHZ RAM + 4GB AMD ram PSU: Corsair CX450 CASE: Corsair Spec-03 OS: Win 10 64 bit Keyboard: Logitech G510s Mouse: Corsair G300s Camera: Canon EOS Rebel T5
I like outdoor warning sirens. Ask me anything about them.
https://linustechtips.com/topic/531979-need-help-with-upgrades/#findComment-7061376
