As the title states, I need a recommendation on a good E-ATX case. But I have a few requirements.
1. The case must be black or mostly black.
2. It must have a minimum of 2 5.25" drive bays to accommodate my card reader and bay drawer.
3. I really would like a front panel door such as the Fractal Define R5 to cover the previously mentioned expansion bays. Let's be honest, they're ugly as hell.
4. It must have a side panel window. I plan to show off the Maximum viii formula when it comes out. I'm going all out on this build since I can finally afford it.
I've spent days looking for the right case but with my schedule I just don't have the time to keep looking on my own. It's a shame the Define R5 isn't E-ATX compatible.
https://linustechtips.com/topic/531936-help-e-atx-case-recommendation/
The R4 is , officially it's not but an E-ATX board will fit, the board will cover the cable slots but the cables can be routed around the end of the board.
https://youtu.be/ki8JAhdfcb8?t=4m45s
https://uk.pcpartpicker.com/parts/case/#m=106
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
Yes it is. And it's a great case but there are just some things about it I just don't like. For example the fact that the door opens to the left while I always place my pc to the right or that the SSD mounts on the back of the motherboard tray require you to remove the board if you need to swap, install, or remove them. So far it looks like I might have to settle on the R4 but I really don't want to.
There's also the NZXT H630 https://www.nzxt.com/products/h630-white but it doesn't come default with a side panel window. It has to be purchased seperately
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
The Corsair 450D will fit an Extended ATX motherboard.
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
  The door thing seems unsurmountable beyond removing it entirely or never opening it (these solutions seem a bit extreme to me).
The SSDs can be mounted in the 3.5" bays with the supplied sleds if you insist on having them screwed down or virtually anywhre else (even in the back of the MoBo tray position)with velcro/two sided tape/WHY.
Personal aside :-
  I have an R5 with a card reader occupying one of the 5.25 slots as I thought I would take the cards out of my cameras all the time but I find that as I conect via USB to charge the cameras can read the cards then, so the card reader gets MINIMAL use, also I have a DVD reader/writer thing in amother slot as a 'just in case' measure I wish I had gone with some sort of external drive as I have pretty much never used it (would simplify the wiring and improve the air flow a bit [OK neither of those are  needed as I have a solid side panel so looks aren't of the greatest import but it bugs me knowing these 'improvements can be made]) and so the door is virtually never opened.  If it wasn't for the 'it doesn't really matter to me' aspect would remove these two items in a heartbeat. About the only time I do open the door is to get at the fan control as some of the case fans are controlled from it I very much appreciate silence so usually have these fans down low but if I am taxing the system like to be able to have the ability to turn these fans up (no biggie if I forget as the rest of the fans are driven/controlled from the MoBo) .
NB Have lots of fans (5case 1 CPU cooler) running at slow speeds  rather than a few running at 100% to help rediuce noise
   OH the door opening thing would be fine with me as the computer sits to my left but this is not your case (<see what I did there?).  :)
