I do have coilwhine on my 980ti, could my rm850 be the problem?
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/531686-is-my-psu-the-problem/
It should not be a problem... Coil whine is most of the times normal...
well, i cant live with it :P
Built  Not Bought
https://linustechtips.com/topic/531686-is-my-psu-the-problem/#findComment-7055220
Take the coil out
/jk
Surely there must be some way to dampen the vibration with something... hmm I wonder.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/531686-is-my-psu-the-problem/#findComment-7055253
Could be both, really. Even High-quality PSU's can make coils whine. It could be a fan, too, does it happen at every fan speed? Under load?
My old 680 used to have coil whine when running at minimum fan speed, cranking the fan up a little at idle solved that.
"It's a taxi, it has a FARE METER."
https://linustechtips.com/topic/531686-is-my-psu-the-problem/#findComment-7055270
Then sucks to be you.
wow, you just keep to be rude.
Built  Not Bought
https://linustechtips.com/topic/531686-is-my-psu-the-problem/#findComment-7055271
not the fans unfortunately
Built  Not Bought
https://linustechtips.com/topic/531686-is-my-psu-the-problem/#findComment-7055284
Translation of previous post: There's no fix for it.
Well, it turned out there was, (folding@home)
Built  Not Bought
https://linustechtips.com/topic/531686-is-my-psu-the-problem/#findComment-7055318
I heard about that and after a while people were saying it didn't... try it for a day.
well, i will try it for a day straight
Built  Not Bought
https://linustechtips.com/topic/531686-is-my-psu-the-problem/#findComment-7055361
