Hard Drive Cloning Issues
Solved by Enderman,
I want to do this, but I don't have his windows product key. And his current laptop came with 7, he's now on 10.
if the laptop drive has windows 7 on it you can use a keyfinder to get the key out
or look on the bottom of the laptop, the key is usually there
you can use this key to activate windows 10, which you can install for free from a USB drive
if there was windows 10 on the hard drive then you can just make installation media and install windows 10 from a USB drive and it will be activated
