-snip-
Motherboard: Asus H170-PRO ATX LGA1151 Motherboard  ($172.00 @ Mwave Australia)
Video Card: MSI Radeon R9 390 8GB Video Card  ($515.00 @ IJK)
Case: NZXT S340 - Designed by Razer ATX Mid Tower Case  ($149.00 @ CPL Online)
Power Supply: SeaSonic 550W 80+ Gold Certified ATX Power Supply  ($105.00 @ Umart)
Total: $1570.00
Generated by PCPartPicker 2016-01-20 22:07 AEDT+1100
https://linustechtips.com/topic/530844-please-help-im-noob/#findComment-7042594
I have 2 builds but don't know which one too choose
Neither really, I'd suggest you start here, you really don't need an after market cooler for locked chip, and the 390 is a fair bit better than the 970, partly due to potentially better DX12/Vulkan support, but also due in part to saving money on a free-sync display vs a G-sync display.
PCPartPicker part list: http://au.pcpartpicker.com/p/x8FkVn
Price breakdown by merchant: http://au.pcpartpicker.com/p/x8FkVn/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($279.00 @ CPL Online)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard  ($159.00 @ CPL Online)
Memory: Kingston 8GB (1 x 8GB) DDR3-1600 Memory  ($55.00 @ Centre Com)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($69.00 @ Centre Com)
Video Card: Asus Radeon R9 390 8GB Video Card  ($489.00 @ PLE Computers)
Case: Deepcool TESSERACT SW ATX Mid Tower Case  ($59.00 @ Scorptec)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply  ($129.00 @ PCCaseGear)
Total: $1239.00
Generated by PCPartPicker 2016-01-20 22:17 AEDT+1100
https://linustechtips.com/topic/530844-please-help-im-noob/#findComment-7042635
Total: $1239.00
Reason I chose the GTX 970 is because it's cheaper in Australia, and I can get a cheaper PSU by doing so. If you're going to get the R9 390, please don't get the ASUS variant...
On top of that, the reason for the cooler is because you can use BCLK overclocking on GIGABYTE mobos.
not sure if 520W psu is enough for gtx 970, at least it wasnt for me. both builds are pretty similar...
It's enough.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/530844-please-help-im-noob/#findComment-7042652
That whole skylake overclocking on non K parts though seems like a pain, would need a Z170 board anyways
Otherwise what's wrong with the ASUS 390? it looked to have recent reviews
and the cheapest 970 I saw was like 10 dollars cheaper, probably not worth it, there was one for 5 less that has a blower cooler, but who wants a blower cooler
http://au.pcpartpicker.com/part/gigabyte-video-card-gvn970wf3oc4gd
https://linustechtips.com/topic/530844-please-help-im-noob/#findComment-7042669
ASUS cards suck for AMD. They essentially just reused their aftermarket cooler, which is more suited for NVIDIA cards, and went ahead and slapped it on the R9 390 instead (which we all know is slightly hotter than the GTX 970). Just a bad cooler for AMD cards in general. Other brands like MSI, Sapphire, XFX, Powercolor are good but I can't find a decent deal on PCPartPicker.
Eh, picked the Z170 board because it is possible to overclock using the updated Gigabyte BIOS. Nothing too hard.
https://linustechtips.com/topic/530844-please-help-im-noob/#findComment-7042681
ASUS cards suck for AMD. They essentially just reused the their aftermarket cooler, which is suited for a NVIDIA card, and instead slapped it on the R9 390 (which we all know is slightly hotter
Well there's a gigabyte one for $10 more then
https://au.pcpartpicker.com/part/gigabyte-video-card-gvr939g1gaming8gd
https://linustechtips.com/topic/530844-please-help-im-noob/#findComment-7042687
Voltage locked and the same story as ASUS - bad cooler.
They're the two brands to avoid for AMD cards. The rest are fine.
https://linustechtips.com/topic/530844-please-help-im-noob/#findComment-7042709
