Wireless or NAS?
Solved by Firestorm,
I personally have a WD my book live which functions as a backup device as well as a personal cloud, so you can access your files from anywhere in the world, free of charge. I think this has been discontinued, but there is now a My Cloud, which I think does the same thing. You simply plug it into power and an ethernet port and then set it up from a PC. There is an app for both ios and android that can be used to access the files.
