Microphone and Mixer
Hi,
I'm looking at getting an audio mixer so I am able to easily control both my pc audio and my Microphone easily.
I also would like to use an XLR Microphone as I seem to be having issues with USB Microphones.
What would you guy's recommend that is under $100 or under £70 in my currency.
Thanks in advance.
See my Build here!
Intel 6700k -  Strix GTX 1080Ti - Corsair AX760 - Corsair Dominator 16GB 3000MHz - ASUS Maximus VIII Hero
Seagate Barracuda 1TB -  Samsung 120GB 840 - Samsung 840 EVO 250GB - Corsair H100i - Corsair Air 540 White -
Corsair AF120 - 2x Noctua NF-F12 - 3 x Noctua NF-S12
 Dell S2417DG - Dell UH2515H
https://linustechtips.com/topic/530342-microphone-and-mixer/
Uhm, well, Anything from Behringer really, make sure it has phantom power.
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7035619
I forgot to mention I've settled on the Xenyx 502 mixer, it's more the microphone I'm not sure of.
See my Build here!
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7035930
1. MXL V67G
2. Studio Projects B1
3. Shure SM57 or SM58
4. Audio-technica AT2020
5. Monoprice Dynamic microphone
All great options.
Edited by Philosobyte
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7036854
Hold on, so you want to control the audio of your computer going to your headphones/speaker, but at the same time the audio going from the microphone into the computer.
Is there anything unusual about that? That's what audio interfaces and audio mixers are designed for.
Of course, you can't separate your computer sounds individually, you can only control the volume of the output as a whole. Not sure if that's what OP meant, though.
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7037360
Yeah not like individual inputs. But I will hopefully be doing video streaming/recording so I can do on the fly adjustments as I will also be swapping between speakers and headphones.
See my Build here!
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7037370
So I'm presuming your going to plug the computer and microphone into there own input channels and then the a single output to the computer, and using the monitor headphone port on the mixing desk. Then using PFL to only listen to the computer output through your headphones.
The Dick of the audio page!
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7037496
Good call, I originally assumed he meant the USB version. But now I remember the USB version is named the Q502USB, not the Xenyx 502.
Yeah you should seriously get the USB version.
Also, was that $100 for both the mixer and the microphone or just the microphone? I originally assumed it was just for the microphone. If it's for both, then that means your budget is pretty much limited to the Monoprice dynamic microphone + an XLR cable.
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7037568
That's for just the microphone. If the price goes Over doesn't really concern me. As I said USB microphones are being really shoddy on my PC and also like the diversity of being able to use multiple devices.
See my Build here!
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7037624
Just remembered something quite crucial. The Q502's phantom power doesn't go up to 48V, so you shouldn't rely on it to work on most condenser microphones. Dynamic microphones would be fine, though, since they require no phantom power.
The cheapest interface I would recommend is the Mackie Onyx Blackjack - I would rather buy a cheaper microphone than compromise on the audio interface for both sound quality and reliability reasons.
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7037842
The cheapest interface I would recommend is the Mackie Onyx Blackjack - I would rather buy a cheaper microphone rather than compromise on the audio interface.
Would the AT2020 XLR mic work>?
See my Build here!
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7037889
No. Its specifications state 48V, 2mA typical.
Would one of them Behringer Power boosters work?
See my Build here!
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7038964
link please.
edit: also, just to let you know, the microphone list I made - even though you wouldn't go wrong with any of them, I listed them in order of preference :P
http://www.amazon.co.uk/Behringer-PS400-Micropower-Phantom-Supply/dp/B000FG795I/ref=pd_sim_267_29?ie=UTF8&dpID=41EfNxUdv5L&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1175EEBZFYH9Y1EAW0FT
See my Build here!
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7039110
I was a bit confused at first because googling "Behringer power booster" didn't come up with anything :P next time it'd be convenient to state the device's full name.
I haven't heard of this product on forums or from friends, but it seems sound (no pun intended) and there are good reviews - it'll probably suit your needs just fine. You'll need to buy an extra XLR cable, though.
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7039261
Right I'm just going to go for that and hope for the best! Thanks for your help!
See my Build here!
https://linustechtips.com/topic/530342-microphone-and-mixer/#findComment-7042164
