Hi there
Like the name says I'm looking to get into water cooling. I would like to buy a kit that inst going to be a huge amount of money but that will he able to cool both a processor and gpu. What would be my best option without spending a lot of money. I'd buy the GPU Water block after but which kit would have a big enough reservoir and more importantly good enough pump to power all of this?
This will be my first water cooling build so I'm quite new to this so all help is greatly appreciated.
Thanks
https://linustechtips.com/topic/530107-best-beginner-watercooling-kit/
Hi there
Thanks
Get a Kraken x40 (or X41), and a Kraken G10.  Great quality control and easy to use for first timer's.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
Hi there
Thanks
I would recommend EKWB kits if your wanting custom watercooling they're a good base to start off on, or the EK Predator units which are an expandable AIO cooler.
https://shop.ekwb.com/ek-kit-l360-r2-0
https://shop.ekwb.com/kits
I really like the kits that EK puts together. They are more expensive but come with a very detailed instructions manual with illustrations that anybody can follow.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
