Repacking a ISO breaks it
Solved by Bittenfleax,
So how do I rebuild it right?
1. Download ImgBurn
2. Get all the folders you want to create into an ISO (EG, get all of the files out of the old ISO, put them into a folder with the new cfg file)
3. Then select create ISO from files
4. Go to advanced tab
5. Bootable disk
6. Check Make Image bootable
7. Boot image, Google and download/find ETFSBOOT.com (it is an application, not website)
8. Create ISO
I did it earlier today worked fine with another ISO.
