I'm planning on building a mid range - low high end PC for my first build, nothing too extreme. Could someone just have a look through the parts I have looked at (these are interchangeable as I may go for slightly higher end components depending on difference in price) and give me a run down of if this would work without any significant issues and any suggestions for if I would need anything else.
  • Intel Core Skylake Processor i5-6500/3.2 GHz
  • MSI H170A PC Mate
  • Asus Nvidia GeForce GTX 970 Strix (GTX 980 possible if price is not too high)
  • HyperX Fury Black Series 8 GB (2 x 4 GB)
  • Samsung 2.5-Inch 500 GB 850 EVO SSD & Toshiba DT01ACA200 2TB HDD 7200rpm
  • Corsair CC-9011038-WW Graphite Series 230T
  • EVGA 500B 500W 80+ BRONZE PC Power Supply
https://linustechtips.com/topic/529347-first-pc-build-part-check/
Invest in a better PSU like the SeaSonic 520 S12II or the Antec HCG.
Personally, I'd opt for the R9 390.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
  • MSI H170A PC Mate
Whats your budget? That power supply is bad and the R9 390 is better
  • MSI H170A PC Mate
Budget? Location? Goal and usage?
I'm based in the UK but due to where I live I don't pay VAT so that helps keep the price down a bit and the setup I listed came in at around £850 ($1200), probably willing to go up to £1200 ($1700) but that would be at a push as still have to get some new monitors, keyboard etc.
This will mainly be used for gaming, looking for a solid 1080p or 1440p at a push and is reasonably power efficient as utility cost are quite expensive where I am.
There will be work done as well however this should have no impact on the specs.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  (£311.96 @ Novatech)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  (£92.64 @ Aria PC)
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard  (£169.16 @ More Computers)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£61.98 @ Novatech)
Video Card: XFX Radeon R9 390X 8GB Double Dissipation Video Card  (£315.10 @ Aria PC)
Total: £1138.14
Generated by PCPartPicker 2016-01-18 00:39 GMT+0000
Tax free around £950 and add what ever case ya want
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
