I'm looking for the best camera that can be used for  B-roll that's worth it's price. The lower the price the better pls.
The "BEST" camera for b-roll should normally be the same type of camera as the primary camera, to keep the look and feel consistent.  And the "BEST" camera is whatever camera you can afford on the market.
If all you can afford is a $10 supermarket disposable camera, that's your best camera.
Asking for "best" camera is a retarded request.  It's like asking which socks are better, red, white, black, blue, green?
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/528571-best-camera-for-b-roll/#findComment-7014237
Phone camera is a good choise because its cheap and everyone practically owns one
What kind of B-Roll? Pretty much any camera ever made can be used for B-Roll.
https://linustechtips.com/topic/528571-best-camera-for-b-roll/#findComment-7015249
Sony A7 or whatever it is.
Has mind blowing low light performance.
I think this will be good for youhttp://www.buydig.com/shop/product.aspx?sku=NKD3200RB&ref=PLA&omid=103&utm_source=GooglePLA&utm_medium=CSE&utm_item=NKD3200RB&CAWELAID=230005120000355344&catargetid=230005120000548208&cadevice=t&gclid=CI2T8sK0r8oCFViTfgodOXwJ7w
https://linustechtips.com/topic/528571-best-camera-for-b-roll/#findComment-7015255
Any camera with a descent video function is capable of filming a good b-roll shot. A great camera does not equal a good b-roll.
"Graphics and gameplay are not mutually exclusive."
"Nvidia, AMD, Intel, or whatever company out there has only one end goal and that is PROFIT.
If you think these companies exist for any other reason you're gonna be disappointed my dear. CAVEAT EMPTOR"
https://linustechtips.com/topic/528571-best-camera-for-b-roll/#findComment-7015896
If you are looking for that kind or broll shot with the completely blurred out background, the lens is the most important to get that look. The wider the aperture of the lens, the shallower the depth of field gets and the more the background will fade away. It can be achieved on pretty much any interchangeable lens camera with the right lens. Allotof youtubes are using a similar combo of a panasonic gh4, metabones speedbooster, and a sigma 18-35 f1.8 to do their b-roll but it is possible to get similar results for cheaper. An example would be pretty much any of the sony alpha or nex mirrorless cameras that does video with a 50mm f1.8 lens.
here is a relatively cheap combo that should produce decent looking footage for b-roll.
a sony nex 5: http://www.amazon.com/Sony-NEX-5N-Mirrorless-Digital-Touchscreen/dp/B005IHAIMA/ref=sr_1_9?ie=UTF8&qid=1452992511&sr=8-9&keywords=sony+nex+5
and the sony 50mm 1.8 : http://www.amazon.com/Sony-50mm-Mid-Range-Mount-Cameras/dp/B005NX7HY6/ref=sr_1_2?ie=UTF8&qid=1452992896&sr=8-2&keywords=sony+50mm+1.8
And if you want to go even cheaper than that you can use old vintage lenses like canon fd or minolta md lenses with adapters. They can go for quite cheap on ebay. The minolta 50mm 1.7 md is a great lens and can be found between 30-50 usd. If you want a bit of a nicer lens you may want to look for a canon fd 50mm f1.4. they typically go for around 100 usd.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/528571-best-camera-for-b-roll/#findComment-7016154
And sometimes a second camera is not needed for b-roll shots, especially for people working solo.  But of course this also depends on what type of filming is being done.
https://linustechtips.com/topic/528571-best-camera-for-b-roll/#findComment-7016155
If you think low-light performance for b-roll footage is a priority, then you're doing b-roll wrong.
Anyway..
Jeffer, what's your budget?
Your original post is incredibly vague, the actual camera you're going to use for b-roll footage is actually not as important as you might think, especially if it's going on YouTube.
A decent tripod, some lighting and a softbox will have a much larger impact, even the sensor in a modern smartphone can produce top-notch b-roll footage if you know the proper techniques.
https://linustechtips.com/topic/528571-best-camera-for-b-roll/#findComment-7017106
