So when I play Minecraft I want to play at a lower resolution but when I enlarge the Minecraft window to fill the whole screen it changes the resolution to 1080p and my computer can't handle that. Is there a way I could increase the size of the Minecraft window without increasing the resolution?
Got an Android, never going back to apple again (notice I spelled apple with a lowercase and Android with an uppercase)
https://linustechtips.com/topic/528432-minecraft-resolution-problems/
I'm not sure but try setting res to whatever you want then going fullscreen. (Might need optifine)
My Build: Night Fury | i5-6600k @ 4.5Ghz | R9 390 | 850 EVO 250GB | 1TB Seagate | H230 Black
Night Theme User
         Hello Fellow Night Theme User | Why Aren't You Using Night Theme?
For minecraft, Its virtually impossible since resolution is based by the window size.
Decrease the whole resolution of your display might work
I tried it and it didn't work
You can change your display resolution (display properties - resolution). If you set it to 600x800 your Minecraft fullscreen will be at that resolution. :)
I already tried that and it still forced it at 1080p  :angry:
