air or water and which?
sacamoises
i wanna get:
I74790k
asus Z97-A
corsair spec-1 case
and i will need a cooler. I have never owned a desktop before and this is my first build.
I really wanted to get the corsair h100i but it wont fit my case without modding and since im a novice I dont want to let much chance for thing to go wrong... what is the best option for me since I will not be able to fit the h100i in my case? (and I dont wanna change the case)
I am also open to air coolling options. I was first going to get the cooler master 212 evo but it wont fit in the case without slightly touching the acrylic
What about a BeQuiet Pure rock?
they look so damn sexy
nah... it dosent not call me... but thx bro
mmm but giving it a second thought it might be, but I only have a 500W psu
Check out the ID-Cooling 120L.
It's really cheap and reviews are very positive.
Air vs water is really more a matter of just preference and affordability in my opinion. There is a reason why the Hyper 212 is one of the most popular coolers on the market. I really gets the job done while at the same time being relatively cheap and easy to install.
As far as air vs water, I had a corsair hydro series cooler on my CPU, but switched to a Thermalright Silver Arrow SB-E literally just because I thought it looked better. It ended up giving me consistently 10-15'C lower temps. A high to mid tier air cooler can give just as good, if not better, performance that an all in one cooler like the h100i.
I cant find the 120L
huh, wherte can I find that? btw I only have a 500W psu...
Where are you shopping/located?
A 500W PSU is fine. When adding a CPU cooler you're usually just adding a fan or two and that really doesn't put too much on the PSU.
If I were you, I would go with whatever looks the most visually appealing and fits within your budget.
Hyper 212:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Newegg's CPU cooler listing:
http://www.newegg.com/CPU-Fans-Heatsinks/SubCategory/ID-574
Be careful with some of the really large air cooling heat sinks because a small case can sometimes have height issues with them.
What does that have to do with anything?  :huh:
USA
Pure Rock is good: http://pcpartpicker.com/part/be-quiet-cpu-cooler-bk009
Hyper 212:
yeah, the 212 is about 159mm and my case only suports 150mm
Oh, right I see that now in your original post.
The case you have does support the Corsair h50 and h60 coolers. I think the main difference is that the h60 uses a different pump design and has LED lighting on the pump. Oh and looks like the h60 supports AMD sockets, but the 50 does not.
There are low profile air coolers as well.
Noctua NH-L12:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608025&cm_re=noctua-_-35-608-025-_-Product
Thermalright APX-100R:
http://www.newegg.com/Product/Product.aspx?Item=9SIA7WF2RB2380&cm_re=thermalright-_-9SIA7WF2RB2380-_-Product
Silverstone NT06-PRO:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835220058
There are other style low profile coolers as well. These are just the brands that I am familiar with already.
Noctua NH-L12:
if I decide for water I will go with the corsair h80i, but I might not need that much after all. can you give me your opinion about this one pls? http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565&ignorebbr=1
I specially want to know if I would be able to fit 4 ram stick in the z97-a with it
The 212 Evo fits in the case. The 150mm spec isn't the full height between the side panel and the cpu socket.
it says 150W in the description... thats all
150w is the cooling capacity of the cooler and not how much power it draws. For example, your 4790k has a tdp of 88w.
Looks like a solid cooler.
Judging from this picture, the manufacture's product page info and other pictures of it in a real builds from google, it should not have any issues with compatibility with the RAM.
Plus it looks like it would look awesome in any build.
Wow, thanks a lot Troyathy I really appreciate it
