So for my rig I have decided to go with water cooling but I want a list of water cooling parts such as resovoirs etc as this is my first water cooled build and I don't know what's good compared to other company's etc all support is appreciated thanks
PC Gaming Rig
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($418.57 @ OutletPC)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler ($128.99 @ SuperBiiz)
Motherboard: Asus Formula 8 ATX LGA1151 Motherboard ($219.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 32GB (4 x 8GB) DDR4-2666 Memory ($205.99 @ SuperBiiz)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive ($327.99 @ SuperBiiz)
Storage: Western Digital VelociRaptor 1TB 3.5" 10000RPM Internal Hard Drive ($209.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card (2-Way SLI) ($609.99 @ Micro Center)
Case: NZXT H440 (Matte Black) ATX Mid Tower Case ($104.99 @ Newegg)
Power Supply: Corsair AX1200iW 80+ Titanium Certified Fully-Modular ATX Power Supply ($392.36 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM (64-bit) ($130.46 @ B&H)
Speakers: Corsair Gaming Audio Series SP2500 232W 2.1ch Speakers ($219.99 @ Amazon)
Total: $3300
Generated by PCPartPicker 2016-01-14 05:43 EST-0500
https://linustechtips.com/topic/527726-water-cooling/
Don't build a custom loop unless you have enough experience
if you dont know what parts are good and what isnt, then you dont have enough experience
And you should probably do some more research unless you want to end up with a wet PC and dead parts
https://www.youtube.com/user/SingularityComputers/
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003788
You've got a CPU liquid cooler listed. Are you only liquid cooling the GPU's?
gpu/CPU people suggested the cou cooler so I don't no any better but with water cooling means I don't need the CPU cooler as its cooled with the tubing right?
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003792
A friend has a bussines in Oc and liquid cooling really good he just told me to get the parts and he'll do it
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003798
If you know this little about PCs and how they work, don't build a custom water cooled PC
Leave a like if you breathed oxygen today
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003799
-snip-
If it's only for gaming then get the Intel Core i5 6600K. The NZXT X61 Kraken is a very good Watercooler.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($254.88 @ OutletPC)
Motherboard: Asus MAXIMUS VIII HERO ATX LGA1151 Motherboard  ($219.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card (2-Way SLI)  ($649.99 @ B&H)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($89.98 @ Newegg)
Total: $2604.49
Generated by PCPartPicker 2016-01-15 09:54 EST-0500
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003800
Ditch the velociraptor 1TB HDD.. not necessary imo
i was debating getting the corsair liquid cooled msi 980ti.. If I do this plus the x61 for my cou does that mean there's no point in WC?
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003808
well from what I understand water cooling is the best option and my friend as a favor offered to do it as I want performance because of this I just need parts for him..... :/
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003818
building is not all that matters
you also need to maintain a custom loop
this includes cleaning out blocks when they get dirty, replacing the fluid every 6 months to a year, replacing cloudy tubing, etc...
it is not a "build it and dont touch it for the next five years" project
and clearly you dont know enough about custom loops to be able to maintain one properly
i would suggest you just buy an AIO instead
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003829
uh, custom loops are not for performance...they are for aesthetics
you're going to spend $600 on some slightly better overclocks, that's all
you would get MUCH more performance by spending that $600 on a better GPU or CPU
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003843
if you get a factory liquid-cooled 980ti and the X61... you won't have to worry about buying extra component.. everything will be liquid cooled then. GPU and CPU
Watch videos on youtube how to install the cpu waterblock
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003848
theres only one way to learn to maintain it and I just wanted suggestions but ... :/
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003850
Thank you so much for answering the question and helping, so basicly if I do get those components there's no need for a custom loop right? Just to make sure :P
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003860
But if you cant build a custom loop without experience how do you get experience to build one? It's a conundrum.
/jk
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003900
/jk
research
watching others build them, reading everything about them, planning your own, etc...
I knew exactly how to build one and what i needed before I actually bought any parts for mine, and I knew enough to get it perfect first try
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003913
research
Hence the jk.
https://linustechtips.com/topic/527726-water-cooling/#findComment-7003961
