Simple Overclock in the i7-6700K
Solved by PrimeSonic,
From the default settings, for the kind of overclock it looks like you want, you should only need to set the Multiplier to 44-45.
Everything else at default settings should be able to deal with it.
Automatic voltage will generally always be safe and never push beyond a known good value.
Speed Step will also be enabled by default and will have your clock speed and voltage go down when the CPU doesn't need the extra power.
So really, I wouldn't worry about it too much.
