Hey guys i have a proposition for you guys i have $1700 Australian dollars to spend
I am in need of a gaming system i would like it to be a micro atx build i would also like to have a monitor since i don't have one so i'm dedicating $200 out of the budget just for the monitor 24" preferably
im not worrying about overclocking for now but i want good air flow, currently leaning towards the 350D for the ascetics and overall quality of the case but if you have better options with a window i would also take them into consideration.
i'm sorry if i offend any amd fans but i strictly only want an intel processor 1150 socket as for the graphics i'm looking at the gtx 760 not specific but this doesn't limit amd cards from being used and also i don't really have a color scheme but i was looking at red and black but that's pretty main stream so anything unique that looks good will do.
lastly i will be adding a $500 budget for any other things that may be needed in the near future (next month) i will need a new keyboard and mouse i would like the keyboard to be mechanical and they should match with the led's might also want to chuck in some fans and maybe another HHD or ssd.
any help is much appreciated
Thank you
https://linustechtips.com/topic/52751-project-micro/
I came up with this:
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($275.00 @ PCCaseGear)
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($39.00 @ Mwave Australia)
Motherboard:  ASRock Z87M Extreme4 Micro ATX LGA1150 Motherboard  ($159.00 @ PCCaseGear)
Memory:  Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory  ($99.00 @ Mwave Australia)
Storage:  Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk  ($105.00 @ Mwave Australia)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($75.00 @ Scorptec)
Video Card:  MSI Radeon HD 7970 3GB Video Card  ($429.00 @ PCCaseGear)
Case:  Corsair 350D Window MicroATX Mid Tower Case  ($145.00 @ Scorptec)
Total: $1475.00
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-09-03 21:57 EST+1000)
I suggest to wait until Corsair releases their RM lineup in Australia, it should be pretty soon. The RM650 is the same I showed you, but it has fully modular cables and Corsair link, which allows you to monitor the temps and fan speed in Windows. Sorry for not following your red&black color scheme, but those parts are so expensive in Australia, so I went with black&metallic instead. It should run all the current games (discluding Crysis 3) on max settings.
As for monitor, take this:
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/52751-project-micro/#findComment-707207
also for the monitor i am thinking of getting a benq 24"
http://www.benq.com.au/product/monitor/rl2450h/
Get an IPS panel instead for better colors.
Do you need a copy of Windows?
Fyi, you need to quote a post or else the person won't get a notification that you replied to them.
https://linustechtips.com/topic/52751-project-micro/#findComment-710018
ok no problem and i already have a copy of windows 7 pro 64bit
Alright. Here's what I came up with: http://au.pcpartpicker.com/p/1zL3S
2 blue LEDS for the front and back.
https://linustechtips.com/topic/52751-project-micro/#findComment-710450
