Really need help Blue screen(with no text)
Diggy
Hey, i have had a pc for about 2-3 weeks and today when i started the computer the screen went blue (no text or anything) but then i logged in and started to play gta 5 and when i change to 1980x1080 the blue screen pops up again (every time i change resolution) and im wondering if it has something to do with the memory/motherboard/graphics card or something.
Pc
geforce gtx 980
intel i5 6400 with the stockcooler
118gb of ssd (only have 11gb free)
1tb of hdd
Pc
geforce gtx 980
1tb of hdd
And you're saying there is no text on the screen? It's like fully blue only?
Have you tried taking a look at the temperatures of your components while gaming, or have you tried reinstalling the graphics drivers?
it ran on 32-40c when it happend, the blue screen pops upp and then goes away after about 10sec
and yes the whole screen is blue.
Check that your cable is in all the way on both ends, I got a bad HDMI cable once and it would make my screen randomly turn all green. Also An old screen off a friend had a bad component which would make the screen go full white after a few min of use. if you have another monitor try that out to see it it keeps happening.
yep i fixed it a while ago but it was my tv
If you still want to keep the tv or get some money out of it you could take the broken tv up and get the chip ID and just buy that and replace it (so long as you don't have to do any soldering) or you can just sell the LCD and get some of your money back. I did that with an old acer moniter a while back when a capacitor died on the chip and I got more then half back what I payed for the screen so that was nice.
