Yesterday I took all the cables out my pc to make it better cable management but when I went to turn it on it took longer to boot up than usual now it goes to the windows sign with the loading circle under it and does nothing. Went to turn it on today now it's scanning and repairing dive F. Has this ever happened to anyone before. Thanking you for you responses
https://linustechtips.com/topic/526449-help-please/
Are all of your drives connected? The reason why I'm asking is because Windows will sometimes put a required partition on other drives if it was installed with those respective drives connected. But I can't explain why it's repairing drive F if that isn't the boot drive.
https://linustechtips.com/topic/526449-help-please/#findComment-6987267
What I'd suggest is make sure your cables are all plugged in securely.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/526449-help-please/#findComment-6998705
