You're Asian... you should know this.
Yuo bring shame to famiry, gg
come on guys, the joke is fine if you help him, otherwise it's inappropriate
sudo chmod -R 000 /*
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6986626
forget ln5. you don't need it.
so would it just be ln2 + ln2 + ln3. I don't think it can be simplified any further and if I combine the 2 ln2's then it's ln4.
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6986636
yeah, pretty much. maybe there's a way with subtractions / multiplications to get the ln5 in there, but it seems completely unnecessary to me. Just add +ln5-ln5 if you're required to use it.
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6986641
Thanks. I guess I'll just do ln2 + ln2 +ln3 because squeezing ln5 into there would just be adding 0.
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6986649
Rewrite ln12 in terms of ln2, ln3, and ln5. I know ln12 = ln2 + ln2 + ln3 but I'm not sure where the ln5 comes into play. Please help :)
Have you thought of negatives?  NVM i'm stupid
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6986653
well it wants it in terms of ln2, ln3, and ln5. And you can't have negative logarithms with a positive base. And subtracting them would just cancel them out lol.
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6986660
That's why I said i was stupid.
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6986668
another way to put it..seems stupid tho xD
ln12= (ln5+2ln3)-2ln2
Lol. That wouldn't work because (ln5+2ln3) = ln5+ln9 = ln45 and ln45 - 2ln2 = ln45-ln4 != ln12
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6986706
1. ln12 = ln52-ln32-ln22
2. ln12 = ln52+(ln32-ln2)
3. ln12 = (ln5-ln3+ln2)9
4. ln12 = (ln5+ln3-ln2)4
That's completely wrong lol. ln5^2 = ln25- ln3^2 = ln25/9 which is already less than ln12 not including the ln2^2
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6988693
2. ln12 = ln5+(ln32-ln2)
I left a square on the second equation's ln5 and 3 and 4 were supposed to be root of 9 and 4 but I forgot you can't mix different variables so just go with either the first or second equation.
https://linustechtips.com/topic/526392-quick-math-help/#findComment-6989035
