i was looking at getting one but was wondering what type of matnence the need
None, it requires no maintenance.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/526364-predator-360-maintenance/#findComment-6986274
it is to be treated as an AIO until you open it (eg to add more components).
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/526364-predator-360-maintenance/#findComment-6986294
that is nice i want to add a gtx 980 to the loop will the rad have have enough cooling?
I'm not exactly sure that it requires no maintenance after adding more components.
I only know that you don't if you keep the loop as is.
https://linustechtips.com/topic/526364-predator-360-maintenance/#findComment-6986297
ek wb told us on ocn once you open it up its maintenance is handed like a custom loop. without opening theres no maintenance for at least 3 yrs. adding a prefilled gpu block from their website counts not as a modification and therefore requires no maintenance either because the loop is still closed.
the 360 rad will have enoughe cooling if youre adding a single gpu to it. (if youre about to buy a water cooling block for your 980ti check out ek wbs website, they have a prefill service for their gpu blocks with the quick connectors so you can just plug it into the loop)
IF YOU WANT ME TO REPLY TO YOU, QUOTE MY POST.
Fire Strike Score
5820K @ 4.8GHZ - 1.25v / Uncore @ 4.5GHZ - 1.2v / 3000MHZ G.skill 32GB Quad Channel / Asus Rampage V Extreme / 950 Pro Nvme / Sound Blaster ZxR  / 980 TI / Windows 7
https://linustechtips.com/topic/526364-predator-360-maintenance/#findComment-6986416
thanks i was planning on getting the stuff from there website also. as of now my master case 5 only supports rads in the front of the case will that be a problem with how the pump is attached to the to the system or should i go down to the 240 and also get the upgrade for my case?
https://linustechtips.com/topic/526364-predator-360-maintenance/#findComment-6986460
dont know about the fitment in your case but theres some compatibility configurator in their website. 240 would do its job too (they announced a 240 predator with quick connects 2 days ago too!) but for cpu and gpu id pick the 360 predator. it's also not recommended to install the Predator in the bottom of a case because the pump could suffer from the lack of water flow. (quoting ek wb here from OCN) so front with the pump on top/top mounting only.
Fire Strike Score
https://linustechtips.com/topic/526364-predator-360-maintenance/#findComment-6986559
ltt has been boulding in this case recently and just saw the 360 setup in it so that answers that also it is only 10 more dollars us so it is a no brainer
https://linustechtips.com/topic/526364-predator-360-maintenance/#findComment-6986942
The unit can be oriented with the pump on top or on the bottom when you use it in the front of a case.
https://linustechtips.com/topic/526364-predator-360-maintenance/#findComment-6988204
