Sounds like your first flash drive is broken... does it work for other stuff?
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/526216-usb-drive-not-bootable/#findComment-6984402
Some flash drives can't be booted from. I've had some drives that work just fine for storage, but won't become bootable, no matter what I tried.
EDIT: Something you could try is going into Disk Management and seeing if the drive has multiple partitions. If it does, combine them all into a single partition and re-format.
@Arty edited the post with something you could try. Maybe try using third party formatting programs too.
https://linustechtips.com/topic/526216-usb-drive-not-bootable/#findComment-6984407
yea works just fine.
Damn
https://linustechtips.com/topic/526216-usb-drive-not-bootable/#findComment-6984439
I tryed everything
CMD
Linux Gpart
Minitool
fuckin Sandisk
https://linustechtips.com/topic/526216-usb-drive-not-bootable/#findComment-6984454
Ah, it's a SanDisk drive? Did it have their weird "vault" security thing? I've got once of those drives that can't be booted from.
Nope
it didn't have any of that thrid party stuff on it.
Try to use rufus to create a bootable usb
tryed no luck
https://linustechtips.com/topic/526216-usb-drive-not-bootable/#findComment-6984472
