80mm Case fans
Vespid
Hey guys,
I'm building a budget pc with an AMD x4 860k and a gtx 750 2gb (non ti).
I have a case that my brother gave me but it has no fans.
It has 2 80mm in the back, 1 80mm in on the side (and a 120mm in the front but the front panel is right in front of it, is it usable?)
I was wondering how many fans I needed and where? I'm also open to suggestion to some good BUDGET case fans! :)
Three at most, but you can get away with two if you get good fans since the 750 is good on cooling.
You'd need one on the front, generally, and then one in the back.
You're also not going to find "good" 80mm fans on a budget, but here are my suggestions.
Most expensive/best ones you can get: http://www.newegg.com/Product/Product.aspx?Item=9SIA2W03KG5832&cm_re=80mm_fan-_-35-608-069-_-Product
Mid-expensive/average performance: http://www.newegg.com/Product/Product.aspx?Item=N82E16835608056&cm_re=80mm_fan-_-35-608-056-_-Product
I wouldn't go any lower than this: http://www.newegg.com/Product/Product.aspx?Item=N82E16835352004&cm_re=80mm_fan-_-35-352-004-_-Product
In the front there is only the 120mm one but I'm not sure it is usable because it's right behind the front panel. Would it be able to get air?
Can you take a picture of the case? They wouldn't put a fan grill there if it wouldn't suck in air, unless it's an overpriced Corsair case (#shotsfired)
I can't seem to upload the images directly so here's the Imgur link https://imgur.com/a/dKBIQ
Lol. Wow.
Okay so, what I would do is save a few bucks and just buy a new case. How much would you be able to scrap up, you think?
Lol. Wow.
Is it that bad? :P About 50€ :/
Get this case. It comes with all the fans you need already configured where they need to be.
If you have Micro ATX: http://www.amazon.co.uk/dp/B00BTQD40W/?tag=pcp0f-21
If your motherboard is ATX and not Micro ATX, get the N300 instead - you can pick the case models on the same page.
Alright thanks for your time and help! :) The N200 looks perfect for me (I have the Asus A88XM-E Micro-ATX)
For 80mm fans, I use Noctua Reduxes. They're cheaper then their more expensive counterparts, and look cooler.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
seriously, before you spend ~30 to 40 bucks on fans for that case, get a decent MidTower that comes with 2 or 3 fans, even if it means saving a few bucks more^^
"We cannot change the cards we're dealt - just how we play the hand" - R. Pausch
CPU: Ryzen 7 3700X , Cooler: BeQuiet Dark Rock 3 Motherboard: MSI B450 Mortar Titanium RAM: 16 GB Corsair LPX 3200 GPU: EVGA RTX2070 XC Storage: Adata 120GB SSD, SanDisk 1TB SDD, 2TB WD GreenHDD Case: Fractal Design Define Mini C PSU: EVGA Supernova 650GS Peripherals: Master Keys Pro S, Logitech G402 Audio: Schiit Fulla 2 + Sennheiser HD 650. Laptop: Asus Zenbook UX 302
Yeah don't worry I'm getting the n300 case :) I may use the old case for a custom mod with old parts i can scrap around or something! :) SCRAPYARD WAR!!!
ΜΟD
Code-name Nyx: R7-3800X w/ Scythe Fuma 2 Rev. B | Sapphire RX 5600XT | Gigabyte B550i Aorus Pro AX | Patriot Viper 4 Blackout | 3TB NVMe Storage| Cooler Master NR200 | Kubuntu/Windows 11 | Xiaomi Mi Curved 34" | Keebwerk Mega | Logitech G602 | Audio Technica ATH-M40X| Edifier e25 Luna
Use drillbits and dremmels to open new fan holes. There are videos on youtube (even from NvIdia Showing you how to do it)
