Overclocking gone wrong.
Go to solution Solved by yannickverc,
How do i do that?  I have a gigabyte gaming 3 skylake.
Your bios has different tabs probably. One of the last tabs you have has the "Exit and save" button and some more buttons. Usually there is also a button that says "reset to default settings" or something alike.
Set bios to default settings again.
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/525842-overclocking-gone-wrong/#findComment-6979086
https://linustechtips.com/topic/525842-overclocking-gone-wrong/#findComment-6979106
I found a button that i think resets it. Now i will try to use pc again and see if it still crashes. I don't think im going into overclocking again in the future though. At least im not if i dont need it desperately ;D
Can a pc crash if it has amd graphics card but Nvidia Physx installed. Because i just discovered that i have physx installed.
https://linustechtips.com/topic/525842-overclocking-gone-wrong/#findComment-6979161
Yea overclocking for the first time alone isn't a good idea.
Err, sorry for the late answer, was at work, but I'm not sure.
https://linustechtips.com/topic/525842-overclocking-gone-wrong/#findComment-6979963
