http://pcpartpicker.com/part/fractal-design-case-fdcacore1100bl
doesn't fit tall coolers well either, but it's at least not shit.
this fits taller coolers
http://pcpartpicker.com/part/nzxt-case-s210001
https://linustechtips.com/topic/525823-ive-got-40-for-a-case/#findComment-6978769
I'm trying to finish off my budget build, and the only thing missing is the case.  This is the build.  I was looking at the rosewill fbm-01 but it doesn't look like it fits tall coolers well.  Any recommendations?
Cooler Master N200 is a good option, but right at the top of your budget.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/525823-ive-got-40-for-a-case/#findComment-6978776
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/525823-ive-got-40-for-a-case/#findComment-6978809
how about craigslist?
https://linustechtips.com/topic/525823-ive-got-40-for-a-case/#findComment-6978810
How much did you add in the way of fans?
I'm going to be throwing in a non-reference R7950 so I want good airflow
Just bought a cheapo $5 one and tossed it in. I actually have a HIS 7950 in it, so if you've got a better one than that, you should be fine.
https://linustechtips.com/topic/525823-ive-got-40-for-a-case/#findComment-6978988
Don't cheap out on a case. Honestly you will pay for it long term with shitty thermals and no dust filtration.
Stretch your budget and get a s340. Its as much case as anyone will need and doesn't lack any functionality.
Yea don't cheap out on ur case like I did, I regret it so much
https://linustechtips.com/topic/525823-ive-got-40-for-a-case/#findComment-6987122
