Web hosting help
Go to solution Solved by Hazy125,
Usually Windows = ASP.NET backend for your website while Linux = PHP backend. You can get both to work on either but meh, Windows fails at handling PHP without some annoying configuration time and Linux fails at ASP.NET from a performance standpoint, even going through Apache CGI stuff.
I suggest going Linux, if you want to actually learn how to use dynamic server side programming crap, PHP is easier to pick up and use. If you're not willing to spend a couple of months to properly learn stuff and test and what not, a service like squarespace might just be easy. Although, I've never actually used them and have no idea if they have YouTube API stuff. It might be simply not feasible to run a proper site for a YouTube channel with squarespace
EDIT: You can get fairly good web hosting for like $5 a month. If you wanna play around, it might be worth trying that. Don't splash out on a $15 VPS or do what I do and have a couple of $150 per month dedicated servers
Ive been looking at different web hosts and I have noticed that most have Linux and Windows packages so I wanted to know what the difference is between both operating systems also if i had to make my own web server should I use windows or Linux(price of software doesn't matter)
Hello
https://linustechtips.com/topic/525313-web-hosting-help/
i dont know much, but i know you should use squarespace kappa
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/525313-web-hosting-help/#findComment-6972357
Go with Linux hosting.  Unless you are going to get a dedicated server and handle your own configurations which is very expensive, you'll be using shared hosting.  As for what sort of hosting you need... that's for you to figure out.
What sort of bandwidth, storage space, number of email accounts, etc. do you need for your website?
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/525313-web-hosting-help/#findComment-6972423
If i got a dedicated server would I need server hardware or could i just build a PC with an I3/I5 ? and should I use Linux or Windows for my own server? The website is for my YouTube channel
Hello
https://linustechtips.com/topic/525313-web-hosting-help/#findComment-6972469
You can rent a dedicated server from a hosting company... but do you need it? Can you afford the price?
If you have absolutely NO CLUE OR IDEA about web hosting, perhaps you shouldn't be thinking about creating a website at all, or go do some research on your own.
https://linustechtips.com/topic/525313-web-hosting-help/#findComment-6972495
I was thinking about using squarespace. I just wanted to know the difference and was thinking about making my own server because it would be a good learning experience
Hello
https://linustechtips.com/topic/525313-web-hosting-help/#findComment-6972543
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/525313-web-hosting-help/#findComment-6976817
