Anti static needed for case swap?
Go to solution Solved by Godlygamer23,
You can occasionally touch the fan grill of a power supply(while it's plugged in) to discharge any possible static electricity. That being said, if you find yourself getting shocked a lot in your own home, I would advise investing in an anti-static wrist strap.
Anti static needed for case swap? how do i ground my self?
| CPU: Core i7-4790K  |  Motherboard:  MSI Gaming Z97 GAMING 5 LGA 1150  |  CPU Cooler:  NZXT Kraken X61 |
| GPU: Single 8GB EVGA GTX 1070 FTW |  RAMCorsair Vengeance 16GB (2 x 8 GB) DDR3 1600 MHz |  CaseCorsair 330R Titanium Edition
https://linustechtips.com/topic/524765-anti-static-needed-for-case-swap/
Before you unplug your PC just tap the case to ground yourself (with the PSU still in the case and connected to the mains).
Thats all i did and well here i am.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
