Is a low end GPU worth using for Physx.
Hey, members of the best forum out there !!!
So while dying of boredom, I decided to find a GT 620 and put it into my rig for some testing. Needless to say, it didn't quiet keep up with my GTX 770. So then I decided to see if there's any use of it being a dedicated physX card. Put it into my system, overclock both of my GPU's and start the testing. So let's get on !!!
I use 326.80 BETA drivers and use the Nvidia control panel to set the card options. Used mafia 2 benchmark, with physx turned up to it's max. I got an 8350 @4.4Ghz  and a corsair TX 750
So let's see:
A GTX 770 with a GT 620 set as a dedicated Physx card
Now, a GT 770 without a dedicated Physx GPU, it's on it's own:
So in conclusion, a low end card like a GT 620 isn't worthy at all, I think you may need a GT 640 if you wan't similar or even more performance.
 AMD FX 8350, ASUS GTX 770 DirectCUII, ASUS SABERTOOTH 990FX R2.0, CORSAIR TX 750, CORSAIR VEANGENCE BLACK 8GB'S 1600Mhz, Hyper 212 evo, Aerocool Strike-X GT, Crucial M4 128GB SSD, Seagate Baracuda 2TB, Asus CrapReader
https://linustechtips.com/topic/52462-is-a-low-end-gpu-worth-using-for-physx/
Modern GPUs are so fast, that they will not need a dedicated Physx card.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
Linus did a test like this 'back in the good old days'
Yeah, but these are different GPU's.
I miss the good old days, when I used to re-watch his videos twice a day ;(
i tried this with a titan and a 660ti and it half my FPS
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
Wait... You're gaming @ 170Hz? O.o
Physx should just die. No one needs a dedicated card for it anymore since all the Nvidia cards are sufficient on their own. As much as I like seeing cool eye candy in games, there is no need to limit that to a specific brand.
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
I totally agree with you, a high end GPU is more than plenty for Physx. And spending aprox 100$ for a 650 is an overkill for a bit of performance and even less effect that physx has to offer
Insane Refresh Rates FTW
I would save that money and get another card later on and go sli.
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
Well unless you can sell it, something they some to be quite good at.
It's not selling anymore. Borderlands 2 and the upcoming Batman game are the only big games with physx coming out.
It's from one of many my old rigs :D
170Hz + 1280x1024 (5:4 aspect ratio) = What the...?
Imposibru you say?
Imposibru you say?
The fastest 1280x1024 monitor I've seen is like 75Hz. 170Hz is rather unusual refresh rate and 1280x1024 paired with it would be so rare it's almost non-existent.
Never trust my advice. Only take any and all advice from me with a grain of salt. Just a heads up.
Even if you SLI only one card gets used for physx.
You can turn one card off in SLI and use it for dedicated physx but the results are much worse than just running it in SLI and not having a dedicated Physx card.
I have considered using one of my 560's along with my 7970 for physx, anyone tried this with similar cards? and got good results?
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
You can scroll up this thread and watch the video Linus made
not relevant as i am considering using an AMD card with a Nvidia card, and my cards that i am using are nowhere near the miss match Linus used
