basic programming help
Solved by Shoob,
What does this mean?
what do they find and replace? Is that something that programmers (not me) know about? Also can you explain the values behind the defines?
It replaces the key with the value. (START = 8 ... etc.). It doesn't take up memory so it's mostly used for embedded programming.
You can read more here: https://www.arduino.cc/en/Reference/Define
As for the values, I don't know what they exactly are looking only at the defines. I'm not experienced in embedded programming, so I can't help much with that.
