if the temps you are noticing now have been lower when the laptop was new, cleaning out the heat sink vents should improve you temps. If the the laptop is new, you could try re-pasting the thermal compound and see if that makes a difference. With the G series from ASUS and laptops in general, GPU temps can affect CPU temps. If your GPU is not 'idling' while the CPU is, the CPU temps will be higher - check GPU idle temps as well.
https://linustechtips.com/topic/52420-3610qm-idle-temps/#findComment-701746
Idle as in nothing's going on? 35-45 degrees should be normal. If you're doing anything or suffocating the laptop, your temps don't seem too bad.
https://linustechtips.com/topic/52420-3610qm-idle-temps/#findComment-701748
Notice that idle is not when you're watching YouTube or Netflix, it is when the computer is doing nothing else than being turned on. This seems to be a common misconception for some reason.  :wacko: However if it is truly idle this does sound a tad high, and cleaning out the heatsink might be a good idea. Of course take care that you don't void any warranties (that is if you care about that, some of us don't ;) ).
https://linustechtips.com/topic/52420-3610qm-idle-temps/#findComment-701776
i dont remember what they were when it was new :/, and the gpu is a 670m and its running at 60
there is nothing obstructing it
nope completely idle no programs running :(
https://linustechtips.com/topic/52420-3610qm-idle-temps/#findComment-701842
Time to dust clean it. If that doesnt fix it go buy some ic diamond and put that on the heat sink.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
https://linustechtips.com/topic/52420-3610qm-idle-temps/#findComment-702382
G series laptop allow you to easily remove a back panel and get access to the two heat sinks and fan assemblies. Just take a look on the inside where the fans integrate to the heat sink. Usually over time a 'bed' or 'pillow' of dust get accumulated there, obstructing the air flow, clean that out and check temps again. GTX 670M 60 degree idle is high.
Currently you have tolerable temps, but if ignored, you can expect, temperature related throtlling, shutdowns, and eventually hardware failure.
https://linustechtips.com/topic/52420-3610qm-idle-temps/#findComment-702387
