so i got an ssd a samsung evo 850 250gig and i fresh installed a version of windows 7 ult and it went all well but
for some reason the ssd would just stop working as my desktop will just freeze and not let me do anything and when i try to restart it would refuse to boot and ask me to select a proper boot device
my motherboard is an older model and only supports sata 2 but i know sata 3 has backwards compatibility and it is set on IDE mode so i think this may be causing the problem
but all i know is the ssd is not faulty and is fully working and healthy so i am not sure what to do my plan is to change to AHCI and fresh install windows but at the moment that is where i am am any help or recommendations would be useful
https://linustechtips.com/topic/523996-ssd-not-booting-help/
if your Windows is set to achi mode then you won't be able to boot when the bios is in ide mode
same goes for if Windows is in ide mode and bios is in achi mode
it is prefered to use achi mode for ssd
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/523996-ssd-not-booting-help/#findComment-6957174
In case you dont know. Never defrag your SSD.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/523996-ssd-not-booting-help/#findComment-6957192
Why if I may ask good sir?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/523996-ssd-not-booting-help/#findComment-6957221
Because SSD´s are not designed for defragmentation and there is a very high risk you kill it. Lifespan will reduced alot, even if you dont kill it. Thats why Win7+ disable autodefrag automaticly when you install a SSD.
https://linustechtips.com/topic/523996-ssd-not-booting-help/#findComment-6957372
