CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/523528-cheep-water-cooling/
dont watercool if your budget is so small
unless you enjoy having crappy chinese parts leak and kill your PC
just get a decent air cooler, it will perform better and be cheaper, and most importantly, not kill your PC
https://linustechtips.com/topic/523528-cheep-water-cooling/#findComment-6952045
So I have always wanted to get into water cooling, but it is so expensive. So i thought why not get some cheaper parts? Will this water cooling setup beat a 212 or not?
I have the first water block you linked, its surprisingly really good. Just beware with that radiator, its aluminum so there is a higher chance of your loop getting nasty from mixing metals, and if its anything like my eBay radiator then it won't come with screws nor threads that are the same size.
https://linustechtips.com/topic/523528-cheep-water-cooling/#findComment-6952053
