I'm looking to have 2 GPUs in SLI. I just want to check that these 2 cards would work together and work as they are intended to under full load with a 650W power supply.
Card 1 - EVGA GeForce GTX 970 Superclocked ACX 2.0 - https://www.pccasegear.com/products/29313
Card 2 - EVGA GeForce GTX 970 SSC GAMING ACX 2.0+ - http://www.evga.com/Products/Product.aspx?pn=04G-P4-3975-KR
Power Supply - Corsair RM650 - http://www.corsair.com/en/rm-series-rm650-80-plus-gold-certified-power-supply
Thanks
Turtus
https://linustechtips.com/topic/523470-gpu-help/
They would but sli 970s is dumb, get a 980ti or if you NEED 2 GPUs get 2 390s
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/523470-gpu-help/#findComment-6951361
Thanks
Turtus
GTX 980Ti performs the same, generates less heat, uses less power, and has 6GB of VRAM.
Please don't do GTX 970 SLI.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/523470-gpu-help/#findComment-6951375
One single faster card is always better than two slower ones, but if you already own a 970 and need more performance, they will work.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/523470-gpu-help/#findComment-6951378
They have a 650w power supply, why would they put themselves in a position to have to buy two cards and a PSU when they can buy just one GPU?
OP, you're somewhat limited in VRAM by using those two 970s in SLI but it would work. Selling the 970 you have and getting a 980ti is an option too. What resolution do you plan on gaming at over the next year or two?
If anyone asks you never saw me.
https://linustechtips.com/topic/523470-gpu-help/#findComment-6951382
Yes I have 1 970 already. The 1 under card 1. But will the 650W power supply affect the preformance of both the cards at all?
PSU´s have no impact on the Performance itsself. They deliver enough Power or they dont. In your Case everything should run just fine.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/523470-gpu-help/#findComment-6951526
Ok so if I don't do any heavy overclocks and I leave everything how it is in this build http://pcpartpicker.com/p/xRCx7P and just add Card 2 to the build everything should be fine?
https://linustechtips.com/topic/523470-gpu-help/#findComment-6951548
Yes
https://linustechtips.com/topic/523470-gpu-help/#findComment-6951570
Well. No overclocking would be the best. Since outside of stock clocks can make power consumption shoot up(not too drastically) And you only have a 650w unit so not much of a headroom there. Your system will run fine on stock.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/523470-gpu-help/#findComment-6951630
