So basically my CPU cooler uses this http://www.amazon.com/AVC-0-50a-4-Wire-80x25mm-DL08025R12U-PS14/dp/B00I4A9U6I Which sounds like a jet engine.
Was wondering if this http://www.amazon.com/dp/B00261LB5Y/?tag=pcpapi-20 Would work and wondering how much better would it be in terms of quietness and temperatures?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/523224-decent-fan-replacement/
or you could get Hyper 212 Evo
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/523224-decent-fan-replacement/#findComment-6948292
Have you tried setting a custom fan curve?
https://linustechtips.com/topic/523224-decent-fan-replacement/#findComment-6948822
I know exactly what I can get, I could simply go to Amazon and order a BeQuiet! Pure Rock though what is the point? None, especially since I need around $250 to upgrade my PC.
https://linustechtips.com/topic/523224-decent-fan-replacement/#findComment-6949206
I don't think I can do that with this mobo.. It is one of those crappy stock HP ones, Plus I have a different fan right no hooked straight up to molex ( lol molex ) which has this fanrunning at 100%, even though it is quieter then the one I originally linked I would like one that is a bit better. I can still slightly hear it but no where near as bad as that AVC one.
https://linustechtips.com/topic/523224-decent-fan-replacement/#findComment-6949218
Have you tried SpeedFan?
https://linustechtips.com/topic/523224-decent-fan-replacement/#findComment-6949457
