Random Question: What Demands more Power?
Go to solution Solved by R4STABAN,
In that case they're pretty similar. The thing with 120fps is that it can be held back by cpu (for example) when 60 on a 1440p wouldn't be.
What demands more power? Playing at 1440P or playing the same game at 120Hz?
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/52285-random-question-what-demands-more-power/
You mean 1080p 120Hz right? If so I would say 1440p.
The 7xx and the AMD 79xx cards can run most modern games 1080p maxed out with decent frame rates, about 80-100. However 1440p is too demanding especially when you put on AA.
1440p, you have power more more pixels at once.
Listen if you care.
Yeah, 120Hz at 1080p guys. I just marked nite's answer as best solved so you guys would know...
2560*1440= 3,686,400 pixels*60fps=   221,184,000
1920*1080= 2,073,600 pixels*120fps= 248,832,000
1080p at 120hz requires more gpu processing power. But not by much. Just shows you how many more pixels (56.25%) a 1440p screen has over a 1080p
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
120Hz easily. 2560X1440 is easy to get because you just set the resolution settings but if you have 120Hz monitor then your card and game could never reach it. That is why I don't see the point in getting a 120Hz monitor as 60Hz is sometimes hard to achieve (if you play the games I do, they are all really poorly optimized).
 (\__/)
(")_(")  GTX 1070 5820K 500GB Samsung EVO SSD 1TB WD Green 16GB of RAM Corsair 540 Air Black EVGA Supernova 750W Gold  Logitech G502 Fiio E10 Wharfedale Diamond 220 Yamaha A-S501 Lian Li Fan Controller NHD-15 KBTalking Keyboard
This question makes little sense to me.
120hz is not any more taxing than 60hz except in the gpu's idle state, where it may incur a high idle base clock  (although so does a higher res). This applies to nvidia cards (6xx and up I have tested).
120hz just lifts the 60hz restriction from the GPU. It is no longer 'held back'.
Now if you mean playing at 1440p or playing at 120FPS then that depends on lots of factors, including game, gpu grunt, gpu memory speed + bandwidth, cpu performance etc.
However, the benefit of 120hz monitors is in the pixel response time and the ability to use the lightboost strobing hack, not in the availability of 120FPS.
I guess I'll reword the question.
What will demand more from your gpu? Playing at 60 fps on 1440p, or playing the same game at 120 fps on a 1080p monitor?
