hey guys, I have:
  250Gb ssd and a 1tb hdd
MSI NVIDIA GeForce GTX 970 GAMING 4G 4GB 256-Bit GDDR5 Graphics Card
periferias.
I wanna buy this to complete my computer:
Intel Core i7-5820K Haswell-E 6-Core 3.3 GHz LGA 2011-v3 140W BX80648I75820K Desktop Processor
Rosewill RCX-Z1 Long life ball bearing for over 45,000/hrs CPU Cooler
ASUS LGA1151 DDR4 DisplayPort HDMI SATA 6Gb/s USB 3.1 H170 ATX Motherboards H170 PRO GAMING
EVGA SuperNOVA 850 B2 80+ BRONZE, 850W Semi Modular NVIDIA SLI and Crossfire Ready 5 Year Warranty Power Supply 110-B2-0850-V1
Corsair Carbide Series SPEC-01 Mid Tower Gaming Case CC-9011050-WW
some ram but still dont know.
dont ask me about a budget plz, I dont really have one. i will have enough money for all of that in about a month or two. I have never own a desktop and I have never desktop, only my toshiba intelcore i5 4 threats 2 core laptop. I want a powerfull machine as you can see. but maybe I am aiming too high.. another guy (flexluthorrecommend me this:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($309.99 @ Newegg)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
is that enough to max out my gtx 970?
I want my computer to play games but I have never played before... I am planing to get assassins crew sindicate and gta 5 asap after I build my computer. I want to play @ max settings 1080p 60Hz.
is 16gb ram enough?
I really like the 6 core 12 threats I7 5820k... is there something like the I7 4970k but with 6 cores?
is ddr4 worth it?
I am complete new sow any tips or information or anything will be really appreciated. I barely know what im doing..
ps. im planing to run ubunto in the pc because I dont think that windows is worth it.
https://linustechtips.com/topic/522654-my-first-build-help/
Do you edit/render/3d?
since you "dont have a budget" (and im 99.9% sure you do there isn't wrong with having one)
i recommend getting the 5820k and a 980 ti for the long run
The 5820K build has a Z170 MOBO with it... @OP, you need an X99 MOBO for that CPU.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/522654-my-first-build-help/#findComment-6940762
what I ment with the budget thing is that im willing to save more and more over time... but i dont want it to take me all the way to 2017 to have enough.
I already have a 970 and I wanna use it. and some day in the future get another one If I feel like I want more power.
https://linustechtips.com/topic/522654-my-first-build-help/#findComment-6940775
You need an X99 motherboard for the 5820K!
https://linustechtips.com/topic/522654-my-first-build-help/#findComment-6940782
so I cant use a H170 with the I7 5820k?
No. The 5820K is only compatible with LGA-2011-3 sockets. The H170 board is LGA-1151.
https://linustechtips.com/topic/522654-my-first-build-help/#findComment-6940792
Well, the 5820K is unnecessary if you're just gaming. Just grab a 6600K and Z170 and save up for a new GPU in the future.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/522654-my-first-build-help/#findComment-6940823
If you have no budget, a 4690K, 4790K/6600K, 6700K + Z97/Z170 MOBO would be a great option.
https://linustechtips.com/topic/522654-my-first-build-help/#findComment-6940826
so, the i5 6600 works with both, ddr3 and 4. sweet. is there something more like the I7 4970k that suports ddr4?
6700K.
https://linustechtips.com/topic/522654-my-first-build-help/#findComment-6940850
you think the 6600K wotn bottleneck my GPU
Nope. An i5-4460 won't bottleneck two 980 Ti' s in SLI.
https://linustechtips.com/topic/522654-my-first-build-help/#findComment-6940854
DDR4 only I think. And the 4790K supports DDR3
Skylake is compatible with DDR3 if you have the right MOBO.
http://pcpartpicker.com/parts/motherboard/#xcx=0&s=30&L=3
https://linustechtips.com/topic/522654-my-first-build-help/#findComment-6940869
