Hey guys, I'm planning on building myself my first gaming pc!! I would love to know if the parts that I have are good or if there are better ones that I could go for around the same price range my buget is around $1000 I can spend more if needed
Parts:
Intel Core i5-6500 3.2GHz Quad-Core Processor
MSI Z170A PC MATE ATX LGA1151 Motherboard
Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory
Crucial BX100 250GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Asus GeForce GTX 970 4GB STRIX Video Card
NZXT S340 (Black/Red) ATX Mid Tower Case
Corsair RM 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Microsoft Windows 10 Home OEM (64-bit)
http://pcpartpicker.com/p/xGC3rH
Advice would be very appreciated!
https://linustechtips.com/topic/522631-need-advice/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($97.88 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.88 @ OutletPC)
Video Card: Sapphire Radeon R9 390X 8GB Tri-X OC Video Card  ($388.98 @ Newegg)
Case: Fractal Design Define S ATX Mid Tower Case  ($79.99 @ NCIX US)
Total: $1117.18
Generated by PCPartPicker 2016-01-07 17:37 EST-0500
pretty good upgrade in most areas
cpu got a 5% downgrde
ssd got a boost
GPU got a sizeable jump
psu got a massive jump with crossfire support
get windows 7 from reddit/g2a and upgrade to W10
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/522631-need-advice/#findComment-6940464
Parts:
Looks really nice to me. I did a build for my brother that's nearly identical so I'm a bit biased lol. I'm not sure if MSI boards can do it but I know ASRock boards can OC locked Skylake processors. Check and make sure your mobo can too, otherwise that CPU + mobo combo is useless. I'm not sure if you need 16GB of RAM but it's really up to you if you want to pay the extra amount. Consider an R9 390 instead of a 970 but personally I like the 970 better. Both have their own advantages and disadvantages but performance-wise they're nearly identical.
https://linustechtips.com/topic/522631-need-advice/#findComment-6940475
Total: $1117.18
ssd got a boost
I think Skylake might be better for long term upgrades. I agree with you on the PSU boost for Crossfire though. SSD performance isn't that big of a deal, at least not to me.
https://linustechtips.com/topic/522631-need-advice/#findComment-6940487
2 gens per socket
which means not much of an upgrade path besides kaby lake
Rigs I've Built
https://linustechtips.com/topic/522631-need-advice/#findComment-6940517
Just my personal opinion :P also DDR4 is nice, not to mention locked CPU overclocks.
even though the haswell i5 4690k will overclock higher cause of multiplier overclocking with a aftermarket cooler vs the i5 6500 on stock fan
Rigs I've Built
https://linustechtips.com/topic/522631-need-advice/#findComment-6940544
Total: $1117.18
ssd got a boost
This ^
I would stay with the Corsair RM650W PSU as it's a much higher efficiency unit, and IMO a better quality unit (more important as you have the ability for an OC on the GPU/CPU), and probably forgo the 390X for the 390 (and save some $$$). If you're gaming at 1080p then the 390 will be perfect, for 1440p the 390X might be worth the jump.
https://linustechtips.com/topic/522631-need-advice/#findComment-6940569
This ^
your saying the corsair RM650W is better than a seasonic EVO unit??? learn a little bit before spitting what you dont know......
corsair http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=363
bigger brother of the 750 evo
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=356
also check the tier lists on this sites...
Rigs I've Built
https://linustechtips.com/topic/522631-need-advice/#findComment-6940640
  1. IMO means in my opinion.
  2. Reviews are subjective, kind of like my opinion.
Seasonic: http://www.tweaktown.com/reviews/5800/seasonic-m12ii-750w-evo-edition-750-watt-80-plus-bronze-psu-review/index5.html
Corsair RMx: http://www.tweaktown.com/reviews/7376/corsair-rm1000x-1000w-80-plus-gold-power-supply-review/index5.html
Corsair RM: http://www.tweaktown.com/reviews/5777/corsair-rm850-850-watt-80-plus-gold-power-supply-review/index5.html
So while he is going for the RM series (even though RMx is $10 MSRP cheaper?), it's still a good PSU. Calm down, kiddo.
https://linustechtips.com/topic/522631-need-advice/#findComment-6940801
