Help me find a case
Go to solution Solved by sarfraz,
may be Nzxt 530 full tower you should go with or a cheap option is Thermaltake Commander MSI Snow edition
Hi I'm looking for a case with these features:
-Side panel window that's not easy to scratch up
-A filter on the top fan hole, front, and bottom
-Price range of around $100
-Space at the front for a CD Optical Drive
-Comes with pre-installed fans (maybe like 2-3 fans)
-Good quality
-Mid tower
Thank you :)
https://linustechtips.com/topic/522428-help-me-find-a-case/
NZXT H440
Corsair Carbide 500 series
Fractal Define r4
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/522428-help-me-find-a-case/#findComment-6937665
Phanteks enthoo pro M,
Only has one Back 140 mm fan though.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/522428-help-me-find-a-case/#findComment-6937676
NZXT H440
Fractal Define r4
Great case but doesn't seem like every buck is worth it.
The NZXT case might be the one I will go with, thanks! The Thermaltake one is pretty ugly to me though.
Not my style, but thanks :)
https://linustechtips.com/topic/522428-help-me-find-a-case/#findComment-6937725
Why do you have an 1KW PSU?
it was from another build that was all AMD with crossfire and custom water cooling. I discontinued it because it was raising the temperature of the room considerably and it really uncomfortable to be in the same room with it for extended periods of time.
https://linustechtips.com/topic/522428-help-me-find-a-case/#findComment-6939354
oh ok
Ryzen 5 1600 - GTX 980 Ti - Broke.
https://linustechtips.com/topic/522428-help-me-find-a-case/#findComment-6943764
