Network Issue: Half-second Disconnect
Solved by MeshFile,
You're not reading. There is no modem. There is the fibre line into the property that connects to the Optical Network Terminal (ONT) which converts the optical signal into copper, plugged into the ONT is my R7000 router.
Either way. It's no longer within your responsibility to troubleshoot it. Your ISP should handle that.
FYI all signal needs modulation and demodulation from the last mile so there's always a modem. Not visible to you, but it's there in your properly.
