Need help with LED Strip
Go to solution Solved by W-L,
Hey guys and girls. So I have an NZXT H440 case and I'm trying to keep this damn LED strip in place haha. Because it really does look beautiful with it. Anyway, the original tape doesn't seem to want to stick for long and nor does the new double sided sticky tape I have just used. I don't want to ruin the case at all so do you guys have any tips to keep it there in place? For at least longer than a couple of days haha
Cheers ^_^ <3
Replace it with mounting tape like this from 3M it's super stick:
http://www.amazon.com/Scotch-Exterior-Mounting-1-Inch-60-Inch/dp/B00004Z4BV
Cheers ^_^ <3
https://linustechtips.com/topic/522179-need-help-with-led-strip/
velcro
ed6b3f3b-94ac-44fe-80df-b0363aed19ac_100
https://linustechtips.com/topic/522179-need-help-with-led-strip/#findComment-6934685
Cheers ^_^ <3
https://linustechtips.com/topic/522179-need-help-with-led-strip/#findComment-6934695
