I need a case with dimensions 12in x 6in and shorter then 15 in that fits a micro atk board
|| CPU Intel Core i7‑4790K 4.9 Ghz || Motherboard MSI Z97S SLI Krait Edition || RAM corsair vengeance pro 4x8gb 2400mhz || GPU msi msi twin frozr gtx 1080 8g sli x2 || Case nzxt phantom 410 || Cooling corsair h100i ||
https://linustechtips.com/topic/521719-small-case/
I dunno the dimensions, but the Fractal  Node 304 looks pretty slick (hah, ltt pun) and might suit your needs. you can look up the specs on Fractals website. Although there are some smaller cases out there, they don't sound fun to build in.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/521719-small-case/#findComment-6928389
the node is 10x8x14 it may work
https://linustechtips.com/topic/521719-small-case/#findComment-6928434
I don't think that's possible mate... I think you're either looking at mini ITX or some old dell optiplex cases such as the optiplex 755, 950, or something along those lines.
and, just curious; but why?
I have a dell xps 8700 board (micro atk) I'm trying to fit a computer in a backpack.
https://linustechtips.com/topic/521719-small-case/#findComment-6928455
I see. well, the only M-ATX I can think of then is som optiplex cases, but finding a psu for that is a pain in the ass. epecially if ye want to throw a gaming gpu in there
https://linustechtips.com/topic/521719-small-case/#findComment-6944572
if you have a drill.. you can drill out the rivets in the Hadron Air and put an matx board in... if you're into that... I dont think you can get much smaller than that
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
https://linustechtips.com/topic/521719-small-case/#findComment-6944706
