Since my 780 ti is a zotac variant, there are still bits of orange all over the back of the pcb. A backplate would be the only way of fixing the problem (orange does not fit in a black and green themed build), however I really dont like the look of the evga backplates.
I much prefer the backplate that came on the reference gtx 970, and gtx 980, however they are not available as a standalone unit. Am I correct in saying this, or is there any way of getting my hands on one of those backplates, and would it even fit on my card (are the screw patters same between the 980 and the 780ti?)
the backplate I'm talking about:
http://i.imgur.com/ecsu658.jpg
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/521695-retail-reference-gtx-980-backplate/
I don't believe they have the same pattern
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
I'm kind of interested in it too but I'm pretty sure they have different screw mounts but I still love my 780 ti so not worth trading it away for a backplate
My Cheap But Good Rig: I7-3770s, Intel Motherboard (actually made by intel), 16gb DDR3, Nvidia Gtx 1070, 250gb Samsung 850 EVO SSD, 750gb HDD, Evga 500 BR power supply
No don´t bother, the reference GTX970, GTX980 backplates won´t fit your GTX780.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
I'm thing about getting the screw patterns, or a cad drawing of a backplate that would fit my card, and altering it to get the pattern on the reference 980. I have access to a 3d printer, so that would be a cool little project.
Oh true that sounds like a cool project!
