Hello, so i have an Sapphire ITX Compact R9 380 2gb.
Since my current processor (AMD A10-6700) can't keep up whit the gpu i decided to buy a new processor.
I'm currently thinking of buying an: AMD fx8350 or an Core i5-4460.
Whitch one do i buy? please help!
4460
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/521034-will-it-bottleneck/#findComment-6919665
I'd wholly recommend the i5 4460.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/521034-will-it-bottleneck/#findComment-6919677
i have owned amd a10 6800k , now i got i5 4690k this christmas. im never buying amd cpu again. get the 4460
https://linustechtips.com/topic/521034-will-it-bottleneck/#findComment-6919704
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/521034-will-it-bottleneck/#findComment-6919707
I doubt that apu is much of a bottleneck if you ask me... If you can oc it a bit it should be ok
https://linustechtips.com/topic/521034-will-it-bottleneck/#findComment-6919753
well AMD cpu's are pretty bad and depending on the game and screen resolution i can easily see that chip holding back even a mid-range card like the 380...at 1080p with max anti-aliasing maybe not so much but if the user is playing more CPU heavy stuff such as MMORPG, moba or RTS for example or pretty much anything multiplayer online with more than 10 players on a server that CPU will bend to his knees pretty fast...even with ''a bit of an oc''.
...and so would an FX-8350 in many games that are not very well optimised for multi-core CPU (AKA quite a few games actually) that CPU also share similar architecture and it's ''cores'' even though they run at higher frequencies are just as weak.
Fewer, stronger cores = always better...especially when it comes to gaming.
If you can afford more cores or threads through an i7 then by all means it'll be even better, but between a fake 8 core CPU from 2011-2012 that was weak even back then and a modern intel quad-core CPU...the choice is easy to make.
https://linustechtips.com/topic/521034-will-it-bottleneck/#findComment-6919776
