I'am planning to buy a new case fan and a new CPU cooler. In the first case I was planning to take a Noctua NF-F12 fan for the front of the case but these fans have a really large surface for good preasure. But I was thinking: do you really need a compression fan in the front of your case that is going to push air into your case? And I don't have any ideas for the CPU cooler, do I also need to go for noctua or be quiet or something from another brand?
I have at this moment 2 fans from my graphics card and the stock intel fan. My power supply fan is facing downwards.
https://linustechtips.com/topic/521029-cpu-en-case-fans/
for a cpu cooler we would need some more specs @Thomas_baas and pls follow your topics
motherboard
cpu
case ( if you want aio or a big cooling block )
ram ( that the aircooler wont touch it )
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/521029-cpu-en-case-fans/#findComment-6919656
What's your budget? Are you not satisfied with your current cooling?
https://linustechtips.com/topic/521029-cpu-en-case-fans/#findComment-6921298
My budget is around 80 euro (85.90 US dollar). No, I'am not completly satisfied with my cooling now because I want to let my PC run 24/7 and that means it is in need to be very silent.
Have you identified the loud components in the system?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/521029-cpu-en-case-fans/#findComment-6932243
https://linustechtips.com/topic/521029-cpu-en-case-fans/#findComment-6939475
