Cpu fan for skylake
thezodiacmachine
Planning to get a i5-6600k and Asus z170a motherboard. Not sure what fan to get as i always use the heatsink they provide but this is the first time i getting an oc cpu and it doesn't come with a heatsink.
Recommend me thanks!
Can you link us to where you're shopping? What's your budget?
i am open to getting it from amazon or newegg but prefer amazon as i am from singapore, could get it locally if i can find it. Budget about $50 usd to $80 usd? Not looking into watercooling. Thanks!
Cheap : (http://www.newegg.com/global/sg/Product/Product.aspx?Item=N82E16835186134)
Good : (http://www.newegg.com/global/sg/Product/Product.aspx?Item=N82E16835608018)
Also for people posting in here, USD to SGD is x1.5.
Not to mention that the newegg lineup we have for Singapore is terrible.
Just take a look at this page, no EVO 212s.
(http://www.newegg.com/global/sg/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100238159%20600035298)
Correct me if am wrong. Can a lga 1155 socket cpu fan work for lga 1151 aka skylake mobo? Thank you. Saw a noctua D14 for $80sgd on a second hand site might get that if i go for noctua fan.
If the mounting equipment is untouched, yes.
But beware of second hand stuff, the mounting gear might be missing.
-EDIT-
1155 1151 has the same mounting hardware.
-EDIT-
If the mounting gear is missing is there anyway i can get it? also does cpu fans come with warranty? Thank you!
New products should have warranty that covers the international side.
Second hand products might have them, but things like e-receipt and serial numbering is required for them to evaluate your warranty status.
Would you have any price lists for local shops you can link us to?
Not really relevant since pricing varies in different areas.
Mounting hardware for all 115x sockets are the same.
The NH-D14 would be a good option.
Singapore pricing is another thing, we have items that are literally exactly 1.5 without shipping.
Uhh, the lists seem to need sign ins to download.
SIMLIM square ones xD?
I rather buy from newegg.
yeah. depends on the price there are few shops which are trustworthy and have great price
Is there a cheaper one? if i get the nh-d14 i would rather pay $20 usd more for a h100i
Why? They perform similarly but the NH-D14 is quieter.
Water cooling looks better haha.
anyone knows how much power a intel stock heatsink consumes?
The fan on the stock heatsink and any fan mentioned in this threads consumes a negligible amount of power if you're worried about power consumption.
If you're just curious, I'd reckon it's 1-3w.
i see. that is 1-3w an hour or min? pardon if this is a dumb question
Hour
Hour
Thanks! i was worried that if i decide to get h100i it might consume way more power compared to a heatsink.
Forgot to mention just now. i will be doing a white color scheme with black ram. What heatsink will look nice on it? thanks!
