Best CPU cooler for Intel i7-4790K
Solved by rectinaught,
If you're not planning on oc'ing, why not stick with the stock cooler?
I did so, before, and reached around a 100 degrees Celsius on the CPU. I will always recommend a going with a good CPU cooler and good CPU cooling paste. I have a NH-D15 at the moment and I would not switch it for the world. I max out at less than 70 degrees. I recommend a moderately priced cooler, which would do the job. For example, one of these: Cryorig H5 or H7, Coolermaster Hyper 212 Evo, BeQuiet Dark Rock or the Noctua NH-U9S. I have not had any of these coolers myself, but I believe the good reviews they have gotten.
