Sturdy rack-mounted audio PC?
Solved by Streetguru,
Using it with a band for gigs. Basically, I will have a midi controller sending signals to the computer that will either play back a music file or generate a sound from a software synthesizer.
The problem here is latency, which should be as low as possible. I could get around with a relatively weak PC, but it is good to have a lot of headroom. So when I play a complicated chord or when there is a fast part, the latency won't go sky high (my current problem).
Well then the the FX 8 cores are going to be about your best bet for having a lot of headroom, possibly, unless you just wanted to get a laptop possible
you should also probably spend some money on a large SSD so there's basically no chance of it breaking as you move it about.
