Cleaning cpu
Go to solution Solved by KieranFretwell,
No, it's not ideal it will just take longer to evaporate.
Nope. Just let the component dry for 30 minutes (or longer?). I use 75% on mine and I aired it out for half an hour.
i5 4670k | Noctua NH0-U12S | Asus Z97M Plus | Kingston HyperX Fury 8gb | Palit GTX 980 Ti Super Jetstream 6G | Samsung 850 EVO 250gb
WD Caviar Blue 1tb | Seasonic M12II 850W | Fractal Design Define R5 | Dell U3014 1600p 30" 60Hz
Corsair K65 | Razer Orochi | Bose QuietComfort 15 | Creative SBS A350 2.1
https://linustechtips.com/topic/519738-cleaning-cpu/#findComment-6904425
I've always heard linus and others say that when cleaning thermal goop off of a cpu you should use 75% isopropyl alcohol or higher, will anything bad happen to my cpu if i cleaned it with 70%?
Probably not. May be just harder and take longer to dry
I need S340. But more Define S'ish
https://linustechtips.com/topic/519738-cleaning-cpu/#findComment-6904431
