My 4790K runs hot enough to almost throttle at 5ghz and 1.18 volts. Even at stock speed undervolted it ran at 91 degrees even cooled by a custom water cooling loop. I did a hammer and vice delid, which did not make any difference. I lapped my CPU and waterblock which helped a little. My question is if I completely remove the IHS, will it run cooler without having the thermal resistance of a heat spreader and another layer of thermal compound. My thinking is the IHS has the same amount of surface area to touch the IHS anyway, and that the waterblock will cool it better if it is directly touching the die than if it touches something that touches the die. Any thoughts?
https://linustechtips.com/topic/519660-does-ihs-delete-help-temps/
My CPU runs hot enough to almost throttle at 5ghz and 1.18 volts. Even at stock speed undervolted it ran at 91 degrees even cooled by a custom water cooling loop. I did a hammer and vice delid, which did not make any difference. I lapped my CPU and waterblock which helped a little. My question is if I completely remove the IHS, will it run cooler without having the thermal resistance of a heat spreader and another layer of thermal compound. My thinking is the IHS has the same amount of surface area to touch the IHS anyway, and that the waterblock will cool it better if it is directly touching the die than if it touches something that touches the die. Any thoughts?
I htink most people get a couple °c off their load temps when running bare die compared to a good delid with liquid metal TIM.  What TIM did you use when you delidded? and what processor are you running 5ghz at 1.18v?
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
5GHz is overkill.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
i7-4790k
Main Gaming Rig:
Secondary PC:
i7-4790k
stock speed, undervolted, it ran 91°c on a custom loop?  thats not right at all and you've got some serious cooling issues.  I hit 80c while running 1.365
edit: and you must be the only person on earth able to run 5ghz at 1.18v so congrats there
edit: my bad didn't realize you werent OP
I used Gelid GC extreme thermal compound. If the IHS is not needed, why does it have one?
Because it's harder to get good contact between the CPU and the cooler without it. Just saying, 90 with a custom loop!? Is your pump even working?
USEFUL LINKS:
PSU Tier List F@H stats
its a ton easier to mount with a IHS and it helps spread the heat, hence the name, heat spreader.  Its best to use a liquid metal TIM between the die and IHS, other TIM dont really make a difference.  Get some cool labs liquid ultra/pro.
and you must be the only person on earth able to run 5ghz at 1.18v on 4790k so congrats there
Pump works. I guess I just have a hot running CPU.
or mount problems, or something else, anything other than just a hot cpu.  NO 4790k will run at 90c at stock speed, undervolted, on a well functioning custom loop
*looks away*
How?
Main Gaming Rig:
Secondary PC:
5.0 is life
ok, 4988MHz.... whatever
Any ideas?
removing the IHS will do you no good at all if you get results like you were saying before. you need to figure out where your problem lies first.  I do know that most TIM (like gellid) "pumps out" from between the die and IHS so maybe that is what you are experiencing.  I'd try a liquid TIM between the die and IHS like I said before.  they are the only ones (besides maybe kryonaut) that do not pump out and lose effectiveness
5 ghz 1.18v lol
If you're hitting 90c+ at 1.18v, you're doing something wrong, or your voltage isn't 1.18v.  I only hit 60c with a custom loop under load at 1.33v 5 ghz.
